I have been chasing a problem with my lift pump now for about 6 months. Driving down the hiway, cruise set at 60 - 65, and the fuel pressure gauge is all over the place between 12 and 0 psi [mostly 0 psi].
I have worn out the bolts changing lift pumps, installed the Vulcan relocate kit [a very nice product, thanks Eric], called about every vendor in the TDR, nobody knew how to fix the problem.
Yesterday I bought a Superchips programmer, and installed the perf tow option, and the fuel pressure is rock steady at 12 psi. I noticed that when I turn the key on, the lift pump only cycles for about a second now, where it used to run for several seconds before the upgrade. Also, during the upgrade, the lift pump cycled a time or two, so I have to think that the lift pump function is part of the upgrade.
I have not driven enough yet to see if I got any performance from this upgrade, but if it only fixed my lift pump pain in the *****, then it was worth the $$$$ that I spent on it. Maybe saved me a VP-44 and some real BIG $$$ down the road.
Hope this helps someone else with the same issue... . Happy motoring!
