Fixed Water Leak!
Water Leaking to Inside
gauge cluster
Apparently I temporarily fixed my water in cab problem. There are drain holes for the rear sliding glass window. I released the cable and blew out all the small debris. I also blew thru the holes and it allowed water to drain last night. I still need to get to the root of the problem which appears to be the middle window seal. Thanks for all help.
John
Glad you found it. As for your other question, blowing the hose out carefully from the top is the best way to open one of the sunroof drains.
Gentle blow with air hose otherwise comes loose and falls off and in that situation head liner will be coming down to reattach, just ask me i blew hose off!:confused:
