Flashers quit
Thanks for the help!
Flashers quit
Some time back I was pulling a trailer with double tail lights and I was unloading equipment on the road so I put my flashers on of course. But when I got in the truck I noticed they were flashing iratically. And now they dont work at all. I put a new flasher element in but still no go anyone ever change out a switch? Any ideas?
93 W350 White 4" stack Headache rack with Lights. Gauges 27pnds boost Banks quick turbo. Hand Throttle CB
Make sure you replaced the flasher for the hazard lights and not the one for the turn signals. I just had to replace the one but I accidentally put it in the wrong one and my turn signals were flashing crazy. When I plugged everything back in the right place, everything worked fine.
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo(37psi),PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '97 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
I replaced both of the flashers but still nothing. Surely I didn't burn the switch.
If the fuse panel is the same in the 93's as the 89 the wire from the fuse to the flaser on the back of the fuse panel can burn out, its very light duty. Mine did the same after using the flashers with the trailer (backin up). I had to solder in a new wire from the fuse outlet to the flasher inlet. Take a look at the wire and trace it with a tester/ohm meter.
Just a thought.
Jeh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs. 237,500 miles (380,000 Kms) 7850 Hrs.
Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics
Lil Mack I appreceate your advice that was the problem. I now have flashers again. Thanks for the replies. Scott
93 W350 5spd White 4" stack Headache rack with Lights. Gauges 27pnds boost Banks quick turbo. Hand Throttle CB
