Mike In Geno'Garage catalog they have the new filter and old filter listed.
The LF3935 is standard filter for 24 valves, LF3552 is Micro Glass as you know.
I believe that the 2000 and/or 2001 models have gone to a bigger spud filter. 89 TO 99 were 18" spuds, newer filter would be 20" spud. I think but would have to look at my Freightliner book, that the LF3935 is the filter which I use on the Freightliner/Cummins engine.
I would have your supplier double check their information. Because there is no way that a standard filter can replace a Micro Glass filter. If its the filter I think it is its going to be to big for your 97 (spud,the exterior is same size).
Missouri Mule 96 White 4X4 ST club cab,(grey int. ),5 spd, 3. 54 reg dif, 8 ft bed, 1 ft high cheater boards, front and side of bed,Pofile V bug shield,
99 Freight liner FL60 blue Cummins 24v 215 hp, 520 torgue,6 spd 3. 59 no spin rear, 16 ft dry box (white) 19. 5 low profile tires,Weight 11,000, gvw 23000, 11 to 12 mpg
Bill Thomas (Wild Bill)
