Engine/Transmission (1998.5 - 2002) Flexible exhaust tubing ?
Engine/Transmission (1994 - 1998) Dowel pin done
Engine/Transmission (1994 - 1998) Turbine housing cracks
flex exhaust is a cheap way to do it. works great. i'd recommend spending the extra money for stainless flex. it will last a lot longer than the regular flex. hope this helps. nick
I wouldn't make my hole system out of flex pipe but the way you want to use it is just fine. I use it in two places for the flex of engine and body.
Craig
I had to use a 2' section of flexible when I changed out my turbo & down pipe. Nobody around here works in 4" pipe. Checked with truck mechanic and he said no problem as a pernanent install, as long as I used stainless! Works great.
Rowland
