96 2500 2x4 pretty standard truck with flickering headlights and dashlights. have replaced the multi function (turn signal) switch and headlight switch with no change in symptoms. is not the grid heater.
a small wiggle can be seen on the amp meter as well. have thought that i'm partially loosing the ground or a relay is failing. it also is intermittant in that it may not flicker for an hour or two and the next trip it will be constant for the duration of the trip. my concern is that the lights may simply quit and with my luck would be on a curve, etc.
i sure hope this looks familiar to someone with the cure !!!!!!!
