Not even going to try lifting one wheel off the ground with my little 1 1/2 to floor jack. Works good on the Honda. I would think that a 3 ton would work Ok but then wouldn't want to get one and it not do the trick. What would be worse would be having to listen to the wife:-{} if it didn't work.
Haven't broken out the on board jack and really don't want to but I suppose I should.
What are you using??
