Hi to all! I’m a new member to TDR... I’ve been trying to solve a low power problem. I’ve read many, many past posts regarding low or fluctuating fuel pressure on the 12-valve diesels. I checked my pressure at the fuel filter inlet using a banjo fitting & pressure gauge. My pressure varies from 20+- to 60+- lbs and will bounce the gauge needle at idle & open throttle. I’ve read that others have encountered the same. Just a little background, I’ve owned the ’96 2500 4wd AT since new and just recently noticed a lack of power after towing a larger travel trailer. I’ve changed the overflow valve, fuel filter, heater screen kit, tank pickup filter, fuel tank roll over valve and verified fuel shut off solenoid is working. I also had the reported “vacuum” problem with the fuel tank when opening the cap. Truck has only 97k miles and lift pump & fuel heater changed at 50K under Dodge warranty.
Is it typical to have the pressure fluctuate with the mechanical lift pump?
Thanks in advance!
Geoffrey Greene
Thanks in advance!
Geoffrey Greene
