Fluid Capacities
jake brake and aftermarket exhaust
EGT, Pre or post turbo----Risk?
I wasn't able to find this information using the search function so I thought I'd post the question. What are the fluid capacities for an '03 2500 5-speed? Page 338 of the owner's manual has oil, fuel and coolant and then it begins to list the type of fluids for everything but capacities aren't mentioned.
I also see per the manual that the transfer case drain interval is 60k for schedule B and there is no interval for the transmission. I'm assuming everyone's changing these anyway.
I want to change the following and need fluid capacities:
transfer case
front diff
rear diff (11. 5")
nv4500 transmission
03 service manual specs
nv 5600 9. 5 pints
nv 4500 8 pints
front axle 4. 75 pints
10. 5 rear axle 4. 75 pints
11. 5 rear axle 7. 65 pints
transfer case 4 pints
Been there done this!
Hope this helps.
Bill
