Fluidampr
vibration
Hard starts
when you install the fluidampr on your engine your supposed to put the belt on first then the dampner so how do you do it if you blow a belt on the highway
It can be put on with the damper on. I didn't see that when I put mine on and I had already torqued the damper. I was able to wedge the belt between the damper and fan pulley then I barred the engine over to rotate the belt thru the gap. I wouldn't want to remove the damper on the road.
