Engine/Transmission (1998.5 - 2002) Fluids ???
2nd Gen Non-Engine/Transmission Winter Tires - recommendations?
Engine/Transmission (1998.5 - 2002) gear ratio
Just changed gear oil in my rear diff. The additive I used stated 10% does this sound about right ? Also, I am changing fluid in the transfer case tomorrow , how many quarts of ATF does it hold. . Thanks for your help.
i take it you have a non slip rear end. my advise from sad expierence is only use d/c additive. non of the after market stuff worked for me. some of the syntetics dont need the additive. be sure to do some 360 right and left turns to mix things up.
