I have been changing the pilot bearing in Ford's and Dodge's for some time...
On my 04 with 100K miles we were having problem with a vibration under acceleration... and we pulled it apart to chase it down... . several asked for some photos of how I change the pilot bearing... .
On the Dodge we use a 6204-3/4-2RS bearing...
We machine the flywheel so that this new pilot bearing will press into the flywheel and give the true support needed to the input shaft of the NV5600 or other trans mission... .
IF I've done this right the first photo will be the bearing open with syn. grease that will go to at least 475*F before it starts to melt... this high end grease is the same grease I use in U-joints... it can't be washed away with a power washer..... we than pop the rubber shield back on the bearing and insert it into the flywheel... . see second photo.....
If you have any questions please let me know..... The second post... will show the disc failure and the HD disc we use.....
