EZeis
I'm getting things in order to install a new clutch in my truck. In the past on gasser engines, i've always had the flywheel machined to have a good smooth clutch. The clutch is OE with a pile of miles (323K) on it and I'm sure the flywheel will be worn. Also I have warpage on the disc, flywheel, or plate or all three.
My FSM states you can not machine the flywheel. Flywheel is to be ground with grinding machine instead and not more then . 003" removed. States this in general and doesn't state if they mean diesel or gas engines or both. Are you guys machining your flywheels or just replacing them?
If my flywheel can't be machined or can't be machined, where is a good source for a good well made flywheel. Dealer wants big bucks for a new one.
Thanks!
Earl
Thanks!
Earl
