Ok guys, I am back to nag and whine and complain.
First of all, Chip is awesome and is helping me out as he can.
Second of all, for those of you not up on this, I bought a used box from a guy on the DTR board and am trying to install it with bad luck. I trust him and have no feelings about him that would make me suspicious of him breaking it or sending me a faulty box.
I mentioned trying to hard wire the red and brown power/light wires but Chip said not to. So I did it his way (the right way) with mini fuse taps and female spades.
Brown to #5 and red to #9. All connections are good and tight.
I took the box apart just to make sure all the wires were still soldered and connected after the shipment to Colorado from Maine. Everything is good.
I may run a wire straight to the battery with an inline 10 amp fuse just to double check, unless you guys say not to. I am a crappy electrician and thought I would ask you guys.
Thank you
Nick
On edit: I apologize, I opened this new message from a search window and it posted it in this forum, please move it if you need to!
Thank you
Nick
