Fog Lamps and Running Lights.
"killer dowell pin"
275's + EZ = clutch slip
I see by some posts below that one can put a jumper wire to make the fog ligts work on high beam as well as low beam, i have a 2001 and live in Canada so we have running lights on all the time,will this modifacation work on this truck. Correct me if i am wrong but i think the US trucks dont have daytime running lights and the posts that pertain to this mod come from the US. Please advise if i can do this, i dont really like to try this if its going to mess something up. Thanks.
Fog Lamps
I don't have an '01 service Manual, but all you need to do is find the feed that kills the fogs when hi beam is on. I wouldn't use a jumper with DRLs
Denny
I assume that your 2001 is the same as a 2000.
The Factory Service Manual for model year 2000 shows that the low-voltage (coil) side of the fog lamp relay is in series with one of the inputs to the Daytime Running Light module. Because of this I wouldn't cut any lugs off the relay or run without the relay.
The switched side of the relay—the two large lugs—looks as though it performs the same function as in the non-Daytime Running Light trucks.
The fog lamp relay is a normally closed relay. It is energized when high beams are selected, interrupting the circuit that powers the fog lights. You can keep the fog light circuit energized with the jumper, but this would involve pulling the relay and interrupting the low-voltage side of the relay/ Daytime Running Light module circuit.
It seems to me that you could have fogs-on-with-high-beams by pulling the fog light relay, soldering a jumper to the two large lugs CLOSE to the body of the relay, and reinstalling the relay. Some TDR members have done a stealth modification by removing the relay cover, jumping the two large lugs internally, and then replacing the relay.
