Axekicker
I finally traced down the reason my fog lights turn off-and-on (flicker) while driving. In the main fuse panel under the hood, the female slot which holds the fog light fuse (#41 as I recall) doesn't get a good 'grip' on one of the fuse 'legs' and when I wiggle the fuse, the lights cycle on-and-off and it burns a small round black spot on the 'hot' leg of the fuse at about the mid-point between top-and-bottom. In other words. . the fuse down-leg is not fitting 'snug' into the female connector and it's 'arcing'. I can't see any way to tighten up the female connector in the fuse box. Any ideas?
