2nd Gen Non-Engine/Transmission Fog Lights dont work?????
Engine/Transmission (1994 - 1998) our trucks could be Nissan
2nd Gen Non-Engine/Transmission Howdy
:confused:
I've gat a 99 2500 that I bought from a guy just a couple weeks ago and the fog lights dont work. I tried replacing the 15a fuse and also tried swapping the relay. The bulbs are brand new and still, i got no fog lights. A friend also has a 99 3500 with the same problem. Any other area to check? :confused:
check the power at the back of the fog lights if no power then move to the relay. if you have some power at the relay(coming from the distribution panel) then you need to also check the plug on the back of the headlight switch. hope this helps.
I just fixed mine this weekend. The wire was broken were it goes under the radiator support. It has a wire loom over it. I didn't realize it was broken until it was hanging down. It's easy to break the wire just by driving through brush.
