Fog Lights Quit
The meanings of Acronyms
RECALL 96 RAMS
I have a 99 3500 sport 4x4 and I hooped in the truck today, and clicked on the lights and pulled the fog lights on, and went on my way, but when I got to work, I noticed the indicator light wasn't on, so i hoped out and sure enough they weren't on. I checked the fuses, there all fine, and the bulbs are perfect. these only 22,000 miles on the truck, I was just woundering if anyone had any ideas? thanks for the help
Did you check the relays under the hood??
Edit: There are 2 of them.
98. 5 3500 SLT Quad 6X6 * 3:54 Auto * Waterfall black/red * Custom dually flaps * Rhino lining * All acc's w/leather * Muth signal mirrors * Catz MSC's * 55watt back up lights * Optima Red Tops * 80/100 Head Lights * BD exhaust brake * Banks EGT/Boost/Temp gauges * Mag-Hytec DC&TP * SS bug screen and fender trim * SS Stull diamond line running boards * SS 4" turn down * grill inserts
My Dually
[This message has been edited by Justbeamn (edited 04-05-2001). ]
I had the same exact problem in my 99, turned out to be the headlight switch. The dealer replaced it under warranty.
1999 red QC slt short bed 4x4 with auto, spa gauges, clarion vcp, clarion tv and 2000 polished aluminum rims with bfg MT's. More to come.
Had the same problem with my '99. Took it to the dealer under warranty and they found a broken wire somewhere near the front bumper. It happened right after I changed the oil, but I don't think I had anything to do with it and I can't see where they fixed any wire under there.
'99 2500 4x4 long bed quad cab auto with sport package.
My Toys
Same problem. Headlight switch.
1999 2500 4x4, auto, 3. 54 LSD, HD241, Quad cab SLT, Blk Sport Pkg, 16x8 Eagles, 285 Bridgestone AT, Bilsteins, 100% Amsoil, 80/100w lights, Valentine One, DTT TC/vb, Mag-Hytek trans pan, DD2's, DD TTPM, Isspro gauges.
1992 SC400
1978 Mooney 201 IFR
I had the same problem, headlights worked but fogs didnt, dealer said it was the head light switch. . which he also said was a comon thing to break!
99,2500,qc,SLT,black,4wd,35Klb gooseneck hitch, K&N airfilter, 265/75/16 BFG ATko's
