Fogs light with high beams
Cab to frame bolts
train horns
Kirwin
Has any one figured out the best way to keep the fog lights on with the high beam headlights on the 03s? Was easy in the 97. My Painless wiring kit should be here tomorrow and that's the first thing I want to change about my 03. The service manual shows they are controlled by the front controller which appears to control just about everything that the driver controls on the dash via a relay in the power distribution center. I guess I could run a separate switch to the fog light side of the relay in the power distribution center. Anyone else have a better idea? Ken Irwin
W/O looking at the wiring, hows bout tying the fog lite grnd (me thinks its #86 on relay - diagram on side of relay) to the headlite or marker lite grnd. Then when they are grnded all would work. Just a "quic" thought, but might need more research.
Did seperate the grnd on the markers for a "flashing" when passing and think we could do the same to the fogs. The front controller puts the grnds on by voltage levels from the switch(s). Uses the resistors to change volts for each selection. This leaves us with only the relays to work with, instead of the switch(s) as before. AND remember that DC controls by GROUND(ING) not hot side.
SOTSU!!
\\BF//
