Hi all,
As a follow on thread to my thread on making my own heavy gauge battery, jumper and winch cables out of welding cable, I think I will try to solder the ends on myself.
I used to be a plumber before going to college, so I am confident I can do this with little problem. However, I do have a question about what solder composition is best for this sort of thing?
Specifics:
* I plan to use 2/0 gauge welding cable
* I will be using a torch soldering method
* I am going to use eyelet style end connectors everywhere. Except of course for the jumper cables.
Looking on the McMaster-Carr website, there are a lot of different types of solder, mostly with differing levels of Tin/Lead composition. They give short descriptions as to the ideal uses for each type. So judging by their page, the ones that sound best suited to my needs are:
* 30 / 70 (Tin / Lead) - solder for torch soldering
* 40 / 60 (Tin / Lead) - general purpose dipping solder
* 50 / 50 (Tin / Lead) - general purpose, handles sheet metal and tinning work
* 60 / 40 (Tin / Lead) - most popular dipping solder for electronics
Oh, these are solid core solders. At the suggestion of a few folks in my previously mentioned thread, I am planning to use a type of flux that is electrically neutral and non-corrosive called Supersafe Superior #30.
So... any suggestions would be greatly appreciated.
Thanks all,
Tom
Specifics:
Thanks all,
Tom
