Need the groups help. .
Just had truck in for a inspection on front end It has been drifting to the right when I let go of wheel. . Shop says upper and lower ball joints bad, also had front break inspection, pads o. k. but front rotors are at wear limits.
Question 1 how much should it cost to do the front end work and can one do this as a diy or leave it to the pros? The shop says the rotors have to be pressed on and off and would require new seals as well again can one do this at home or should I leave it for the pros? Again ahy Idea on how much for the rotor job?
Thanks in advance
P. S. Also the break pedal gets very hard at times like the power assist not working anyone ever have this happen?
Thanks in advance
