RustyJC said:If you want to treat the process as adiabatic compression where no heat is transmitted to or from the air from the cylinder surfaces during compression, then you can use the simplified formula:
T2 / T1 = ( V1 / V2) ^ 0. 41
Where
V1 = Initial volume in cubic inches
V2 = Final volume in cubic inches
T1 = Initial temperature in degR
T2 = Final temperature in degR
If we assume a 17:1 compression ratio, 60 cubic inch displacement per cylinder, 100 degF initial temperature (559. 7 degR), then the calculation looks like:
T2 / 559. 7 = ( 63. 75 / 3. 75) ^ 0. 41
T2 / 559. 7 = 17 ^ 0. 41
T2 / 559. 7 = 3. 195097
T2 = 3. 195097 x 559. 7
T2 = 1788. 296 degR
T2 = 1328. 596 degF
Rusty
I "assumed" 100 degF on a 30 degF day (see post #1), but one can plug in whatever temperature they might wish, as well as an effective compression ratio (taking intake valve closing into account) in lieu of a mechanical compression ratio.GFritsch said:I wonder what the average temperature going into the cylinder is after running throught the turbo and intercooler.
Is that assuming a recent valve grind and overhead? :-lafRustyJC said:I "assumed" 100 degF on a 30 degF day (see post #1), but one can plug in whatever temperature they might wish, as well as an effective compression ratio (taking intake valve closing into account) in lieu of a mechanical compression ratio.
Rusty
AMink said:I touched the exhaust manifold after a run the other day. Temperature is between Son of a biscuit and Gol Dang! Imagine it's even hotter inside! :-laf
