For sale delphi fuel pump new
http://kalamazoo.craigslist.org/rvs/3667278108.html
2006 Dodge 2500 4x4 Big Horn Edition SLT
I have a new Delphi Fuel pump with gasket, Was going to use on my P pump conversion but did not. Will sell and ship for $75. 00 in USA
Rick
Have you sold this pump yet? It is the mechanical transfer pump that mounts on the side of the block, right?
Thanks,
CTD12V
No,still have it, just have to find it as we are under construction and my wife put it somewhere! Yes it mounts on drivers side where factor did, it has primer etc, brand new
Rick
yes, and I do not know where gasket is, this is the highest pressure pump for that application made. The reason I did not use it was I P pumped my 24 valve, was going to run my fass and mechanical. With my mods I needed 50 psi. Carter makes the low pressure on I guess?
Will it work on a gen 1 engine with the ve pump ?
I've been trying to figure out the versions of this pump, and haven't found a good answer yet. It sounds like Delphi makes several different model numbers of the same basic pump, but possibly a smaller size plunger and a lower pressure for the VE pump vs. the P7100.
Rick, can you give us the model number off your pump?
Thanks,
Jeff
