For those that have installed gauges, I have a question.
2005 BAJA 1000 streamed over your computer today
Seattle area service recommendations...
I am getting ready to install a full set of gauges, egt, boost and transmission temp and am looking for some links or write ups on installing them. Installing them should be easy but knowing what I need to do to begin with will hopefully keeps the ooooppss down a bit.
Here are some write-ups. I would recommend using the Peirs Boost Bolt for boost setup, mount the transmission temp probe in the pan or the Max Diesel line kit (I think that's what it's called but I mounted mine in the Hytec pan) and pre-turbo for the EGT probe.
PDF gauge install write-up
Boost bolt location
EGT probe
Gauge lighting
Some things to get you started anyhow. Read, read, read and read more before you start. I installed mine a few months ago and never even drilled and tapped anything in my life and I read so much about it before I tried that it actually felt like I had done it before.
Karl
I used the great information from this site as well and had no problems with my installation. I did it about 8 months ago and everything works great. I got the guages from Geno's with the boost bolt and used the Diesel line kit for the trans. temp probe. Just take your time and like Karl says, Read.
Keep grinnin,
i found quit a few threads with great pics that helped me alot, you'll have to use a few diff. words to search so you can get the most number of threads
