I've had my '95 since it was new and I've towed some things, but not frequently and definitely not in real steep climbs. Recently I helped move a relative from Las Vegas to S. D. using the I-15 up through Salt Lake and then across the I-80.
Using my truck, I was towing an 8x16 enclosed trailer that couldn't have weighed over 4,000 lbs. The temp was in the high 80's or low 90's and I entered the climb in OD and AC was on. The truck didn't seem to be struggling at all until about the last 500 hundred feet. During this last 500 ft I noticed the transmission temp and water temp rising and I wasn't getting any more out of the throttle. Of course, I turned off the AC and I even put the heater on to lower the water temp and hopefully to help lower the transmission temp. Both temps never got to the dangerous point, but just as I crested the climb I noticed my EGT was holding steady right at the top end of the yellow zone on the gauge and I can't say for sure how long it was there because I was focusing on the other two temps.
So my question to those of you with frequent hauler miles: What is the best way to use my automatic transmission in situations like this? What should I have done different? On some subsequent climbs I noticed that when I shifted out of OD the EGTs went down almost immediately. Thanks!
