I was talking with a Ford mechanic. He mentioned the 6. 0's will leak oil if any type of aftermarket air cleaner is added. The engine was designed for stock filtration. The extra air causes some type of extra pressure which produces oil to fill a upper reservoir. At the back of the block the reservoir only holds so much oil. It will eventually overflow and leak. Apparently, the oil leak will saturate the clutch.
He did admit to engine problems with the 03' and 04's. To date he hasn't repaired any 05's.
