... well, they worked like a charm. Got them from AutoZone. You'll need 4 boxes to do both doors so figure about $18. The new clips hold the door panel so much tighter it's not even funny.
Anyway, I just finished the first drive since I got everything back into the cab. While I had it apart I replaced every clip, screw and bulb and what a difference it makes. The interior does not rattle one bit now.
I also permanently fixed the vent issue but using some anodized aluminum heating duct screens from HD. I epoxied and riveted them over the openings before putting everything back together. About the only thing that's going to get into the cab now is a really small bug... still better than mice.
Oh... I also used some 2" square stock to raise the seat up. Being almost 6' it makes a huge difference in leg room. For some reason, everything now feels more like it should be there - the steering wheel, the gearshift, the armrests on the door, the height of the door with the window opened. Highly suggest it if you feel there is not enough legroom.
Mike O.
Mike O.
