Cummins724
I have a 99 truck 5 speed, 90hp injectors, volant cold air intake, 4 inch exhaust, edge comp, luk clutch, bullydog big fuel kit [14psi]. Recently I replaced the turbo with the htb2 64/14. With my stock turbo I saw 1350 egt. With the htb2 I am seeing 1300egt. I know it should do better than that, but also I am only getting 40psi boost wide open. [boost fitting at full boost]Spool up is around 1700rpm, so what is up with my truck?
I've heard that if you have small injectors, the htb2 won't fully spool. So if correct how big should I go? How big is too big to tow 7 ton? & How much boost do you guys get with htb2 turbo & bigger injectors? any haulers with similar setups give me a note, cause I "almost" lost a run with a powerstroke today & I am going nuts. HELP!
