Details here: TDR Privileges
Ya it went clunk last one she is dead no 4wd front drive line is turning rear line is turning rear tires turn front NO I guess it must be the front diff gears???? Im at a losss HELP
98. 5? That should be a CAD axle. There's a vacuum motor on the passenger side, it moves a sliding collar on the passenger axle shaft. If that motor can't lock the 2 halves together, you wont have any drive on the front axle.
Okay, assuming the CAD is locked, leave the tcase in 2hi, and see if you can spin the front d/s by hand. If you can, you've got a world of trouble inside the differential.
