formula flux, ddp, or scheid injectors?
MPG Loss?
proper temp of turbo for shut down
Iwas looking at getting some new injectors, thinking anywhere between 40 hp and 100 hp. I still have stock cp3 and no lift pump, but plan on a lift pump at the same time and modified cp3 later. my ? is #1 how big can I go and still run the smarty at lower settings untill I do the cp3? #2 What brand does everyone prefer, quality, service?
thanks
Kevin
i did flux 2. 5 (125hp) and a airdog 150 at the same time and it has been great. i tried a few diffrent settngs with my Jr but the bottom end of the standard programing and the grunt the injectors give was a little to much for the trans. but if i had to do it again i would in a heart beat.
I have the flux 2's and my set up and like them, but I do smoke from idle through 3rd gear. Some of that is the programers, but when you dump a lot of fuel your going to smoke.
Aaron
The 1. 5's are approximately 75 HP. As for size of the injectors, I would suggest the 1. 8's for the stock cp3 system. Smoke is easily controlled, excellent fuel mileage and good power(about 90HP). Also, keep in mind Don will upgrade to larger nozzles in the future if you decide to go bigger for a small fee.
If you need any help with choosing, shoot me a PM.
