2nd Gen Non-Engine/Transmission fornt brakes and rotors
Engine/Transmission (1994 - 1998) injector turbo mods
2nd Gen Non-Engine/Transmission new tow mirror glass replacement
What is the best brake rotor and brake pads for our trucks? Should I go with ceramic, semi ceramic, drilled slotted rotors, or ???
cracked
My drilled rotors crack too.
I'm going with slotted only next set.
I run performance friction pads from Auto-Zone (lifetime warranty).
I got 48,000 miles out of my last set.
Thanks to keeping the caliper bolts well lubed and the 1 ton rear wheel cylinders.
Be sure to check out the pics in my readers rig section for some good tips if you are DIY.
SFB
