Engine/Transmission (1994 - 1998) Found leak in NV4500
2nd Gen Non-Engine/Transmission Washer fluid light
Well, after replacing my clutch, the transmission started leaking badly. the leak was right were the transmission was bolted to the bell housing. Pulled it all apart again and found the dust cap over the idler shaft on the front of the transmission was leaking. I had purchased a new one from Standard. Replacement is holding up fine.
