okay finally figured out hard start. Had vp44 replaced month ago all was fine couple days ago hardstart when cold then couple days fine past 2 days cranks and cranks to start fuel leaking on ground friend at dodge put dye in fuel and says it is coming from number 6 injector only at the bottom of the nut but nut is torqued correct why would this just start should I replace connector tube could it have gone bad on its own or is there some other culprite or should I replace fuel line too????? or could something have gone wrong with my injectors they are Don M mach5's they only have about 3000 miles on them gotta get this fixed asap but dont wanna do twice
