OK, Finally got around to getting the necessary AC test hose to install my Nordskog FP gauge, and something must not be right, cause all I get is 3psi, no matter what, including when the truck is off.
All the mechanical FP guys need not do the "I told you so" routine
..... So, seeing as how my constant 3psi isn't likely, I need some suggestions. The sender is at the end of an 18 inch grease gun hose, which is connected to the AC test hose (only about 4 inches long) coming directly off the VP. Do you need to bleed the air from the hose before attaching the sender? I didn't, because I didn't think it would matter.
Kev
Kev
