Marco said:
Personally I did not know that company. I've asked a few questions to my buddies in the diesel injection scene here in Italy. All responses I got is that Fratelli Bosio is top notch. BTW. they're about 3 hours from my home...
Just one question from my side. It's my understanding that you only buy the injector nozzels. In other words one keeps it's injector nozzle holder and replaces the tips. Right?
During that process one has to adjust the pop pressure of the injector.
How do you do it?
Marco
Marco- you should give Giuseppe a call, he is very busy, but if he can find the time, I am sure he will be happy to show you around. I am proud to know that family, never known better people in my life, you will see this also. 011-960-6222 Bring your truck and give him a ride!
A couple of hints for doing the nozzle swap- USE A VISE or else you are going to drive yourself crazy. After you get them open, cleanliness is the most important thing. A little piece of carbon can mess with the seal between the nozzle and the holder if it gets in there. You can use an old toothbrush and some diesel fuel to clean up the hardened soot and it won't scratch anything. A puff of compressed air can clean up the "crumbs". Clean is also imprortant to ensure accurate torque on the nut so be sure the threads are nice and clean to spin freely. 30 degrees past hand tight is sufficient.
You can pop test them if you want, but it is not absolutely neccesary. Any diesel shop can do it and usually they won't charge much if anything. SOme people do it for the peace of mind, but if you followed the instructions on the web site, all it will prove is that they don't need to be shimmed after all.
VW TDI crowd likes the Bosio stuff, so we figured why not the Dodge? Had to start somewhere. There is nothing groundbreaking about these particular nozzles, the nozzle swap will simply convert your stock injectors into "RV275" injectors, everyone knows it's "only" a 40 hp gain. The difference is the quality of the workmanship, which I think the aftermarket is not used to seeing (I must admit I've never seen DonM's work) Only 7 holes, (for now
) but for sure it is certainly better made than the "made in China" stuff.
Interest seems to be picking up, it looks like we will advertise in the TDR after all.
