Details here: TDR Privileges
I purchased them today from the Charlotte Freightliner/Sterling dealer. 704. 597. 8800
PDT/1519 570102 Rear @ 72. 99/pair
PDT/1510 570102 Flaps @ 34. 69/pair
I parked the truck on cement drtiveway on flat spot. Laid down 4 square plastic gizmos I use to level RV. I then laid 4x4 box down between both plastic gizmos to give me square and level holder for bottom of flaps.
That was the height I wanted them. I had to trim slightly the rear ones to miss the leaf springs. I simply used roofing screws with rubber grommit to fasten them. At the bottom I used several 1/4" x 1" stainless screws and drilled thru fender well.
