Here some likely areas to check:
1) Compressor front shaft seal. These are responsible for 50% or more the refrigerant leakage per year for a system. Very difficult to check because of the clutch being in the way.
2) Schrader valves (charge ports). Ensure the caps are installed tight. Sometimes people leave this off, but the cap is the primary seal for the schrader valve. My low side was very wet with refrigerant/oil and I got a new cap.
3) Check the liquid AC line that is between the fender and the battery on the PS of the truck. The orifice tube is located here with a joint and that area could be leaking, but would be hard to diagnose because its hard to see.
4) Check your condenser tubes for rock or rust damage. This is probably not likely because the condenser tubes are large steel tubes.
When you add refrigerant back into the system, add 2 or 3oz of Medium viscosity PAG oil too. Oil leaks out with the refrigerant. Its available in a little bottle from Interdynamics and can be installed on the low side just like adding refrigerant. This will protect the compressor and also lube the front shaft seal.
