Engine/Transmission (1994 - 1998) Friday the 13th
Engine/Transmission (1998.5 - 2002) Oil additive.
So i had the day off from work today,and decided to install the DDP delivery valves that have been on the shelf for about a year. I changed the engine oil and trans fluid,no problem. I installed the delivery valves,no problem. I went for a test drive,the engine running good,running a little more boost. I didn't do any real heavy throttle driving,just normal stuff,no WOT. Long story short,when i got home I noticed a leak. I opened the hood. I found the coolant overflow tank lid off,and a coolant/oil milkshake in the tank and blown back on the turbos. Head gasket.
Now as I think back on it,I had thought the engine smelled hot a couple of times,but had never seen any leaks. So now I have to decide on what to do. The head is O-ringed,and held down with studs. I am running BD twins with some pump work. I have a 50psi boost gauge and can bury the needle. What do you think,is it time for fire rings? Thanks for any help.
