Engine/Transmission (1994 - 1998) Fridays dyno run
Engine/Transmission (1994 - 1998) Strange blower behavior
2nd Gen Non-Engine/Transmission Did Dodge make this combo?
I started modifying my truck in October last year. It is a "95 Auto 2500 and was stock to begin with. I made several runs when stock to get a baseline reading before I made changes. Stock, I made 132 H. P. and 326 Ft. /lbs of torque. On Friday, with new 215's, a TST #6 plate, AFE filter, timed at 18. 5* and the head is ported and polished on the exhaust side. I made 309 H. P. and 751 Ft/lbs of torque! My EGT never goes over 1050* and I make 32# of boost on the dyno. I also make very little smoke when driving! I still have the stock WH1C turbo also. I am thinking about EDM injectors now. I don't want clouds of smoke every time I open it up. I'm happy for the time being!
Ronco
No, there aren't any dynos in my area that can handle a dually. And I suspect the timing has slipped on the old 95 due to egt issues. I've ordered the necessary Snap on items to check/set timing, then I may travel to a dyno just to see where things are.
RJR
Hey ronco do you have any transmission mods i have a tst 6, afe, 3k spring kit, and mystery switch, and waiting to install a 16 CM housing.
Yes, I have transmission mods. My mechanic has worked with a local shop to update the trans and has had his own T/C built to handle far more power than I am making.
Moparguy, my dyno requires all duallys to remove the outboard tires to fit on the rollers. Not a big deal, he just lifts the trucks and pulls the tires off long enough to get readings.
Ronco
Just out of curiosity have you taken care of the dowel pin yet?
I just read the post the new member wrote detailing his woes.
That should be everyones first BOMB with that year truck.
The dowel pin is cured. I pulled the front cover off, drove the pin back in and peened the bore to prevent the pin from moving again.
Ronco
