HI All,
Had some errands to run first thing this really cold day of winter (approx 22 degrees this AM).
Went to start the truck and let it warm up a bit before heading out (truck was not plugged in). As soon as I turned the key to let the heating grid warm up I heard a pop and smoke came rolling out from under the hood.
I Immediately turned the key to the off position and opened the hood to see where the smoke was comming from... . By the time I looked under the hood the smoke had cleared up enough so I could not tell what had been smoking... . I touched a few things to see wkat had heated up so much as to smoke but no luck..... Battery cables are tight and clean. I figured I'd try to get whatever smoked to smoke again but turning key to start position but no wait light came on... . I tried to crank truck but starter motor didn't even turn... . Headlights do burn Bright..... Is there a relay or something that needs to be replaced? (used to do that on an old 5. 7 I used to own but have no idea about relays on this truck..... I guess I need to buy a Chilton's guide). Thanks for any help.
Andrew
Andrew
