friends durango got a tank of diesel !
Do you miss those old TV shows/B-westerns of your youth?
Moronic ineptitude at the wheel
help dodge has had this thing for a week,wants 1300. 00 bucks and dont know what to do with the diesel mix in the tank(11gals & 1gal of gas). does the injectors in the durango really need to be replaced or are they pullin his crank?
How much could have it towed to Dutchess county (Fishkill, NY) for? I can fix this for less than $1,300. 00! And I know how to get rid of the contaminated fuel... ... legally. Call me 914-464-8896 I doubt he needs new injectors!
once you get it started you should be able to run it. i know on a bunch of older cars we had we would run them with diesel gas mix. when people accidentally diesel in their cars we would drain them out and mix them with gas. That was on an older non fuel injected engine though. They were hard to start but would run fine. It would probably Smoke like He!! though.
Trey
If it's only got 1 gallon of gas in it, put the fuel in a CTD and fill the rest of the way with #2. Maybe add a bit of oil to slick it up a bit.
I'm kind of curious how someone managed to get the diesel fuel nozzle into an unleaded filler.
Have the station pick up the tab ... the diesel nozzle is normally larger and should NOT fit in a standard fuel pipe anyhow. MORESO at a truckstop.
thanks all for your replies & sugestions. getty had 10,000gals put accidentally into their reg. tank. i havent seen him to find out the details but it took more then a week to get the durango back from dodge.
