from 12 to 24
Clutch Replacement
How do I know if my transmission is slipping?
ok, got a 24 valve machine, and have to start learning the new stuff. i know i need gauges{i haven't decided which ones yet}and i need input on which electronic enhancements to use. 2 friends of mine just put on the diablo power pucks and are real happy, but it seems from reading here that there might be more bang for the buck with some of the others. tell me what you got and why.
gauges
I got three on the dash. Boost, Pyro, Fuel Pressure. The most important one for the 24 v is the FP if stock or bombed, because of the lift pump failures. After install the fp was 14 at idle and not less than 8 at wot. Not too long after the fp was 3 at idle and ZERO at everything else. I had 10K miles and new lift pump installed .
If you bomb or tow you should probably have pyro and boost any how.
As for the bombs I know nothing, but most seem to start off with the Edge EZ. A nice 4 inch exhaust straight pipe makes it sound and run good too.
Good luck. Life is good. :D
I like EDGE, but as you know or will know there are quite a few options---some are Edge just relabeled--do your research--EDGE has been around a long time... good luck... chris
