I have an 03 2500 4X4 with a bent front axle at the "C" where the knuckle (hub) end and ball joints attach . It is only bent slightly in, on the top ... I could almost take out the bend using a 2 degree adjustible upper ball joint... I believe that these welded on ends are cast steel (not iron) so can they be streightened by pressing or leverage after I take the knuckle off ???... . any ideas ... ps. big tires and hard objects don't mix ... ... thanks
