Front and rear carpet
Western Diesel rpm module
Need help on a problem with my SPA gauge...
Carpet replacement extended cab
:rolleyes: I am looking to replace the carpet in my 1995 2wd 5spd extended cab and cannot seem to find anyone that sells it I tried JC whitney and they cannot deliver what I need.
Does anyone know where I might be able to find carpet I am looking for orig replacement type moulded
Thanks
This is a different twist but the 1st thing that I did was replace my carpets with deep rubber mats. I just could not understand why I would want carpet in a truck. I climb in with mud on my boots and now I have to clean the carpets...
If you are interested, I can find the name of the set. They cost me around $100 for a quad cab. I got them for my '96 and then put them in my '98. They have been working fine. They hold a quart of mud/snow/sand. When they get dirty I give them a shake. If they are really dirty I pull them out and turn a hose on them. The carpets underneith them are as clean as the day I bought the truck.
Carpets
My problem is that the carpets are a real mess i bought the truck used and they are really so bad the front will not come clean.
The mats you suggested are a great Idea and if you find the info on them I will look into them but I still want to replace the front carpet at least
Thanks again
nopowerforme,You can get it from the dealer,I priced mine it was about $350,kinda expensive,but nothing will fit better. If you go with the rubber,there's another advantage,the radio is louder!:--) 'cause the rubber doesn't absorb the sound. If your into loud tunes.
It took me only a few minutes of searching. The brand name is WeatherTech. You can buy direct. I found the ad in a sports car magazine. There are plenty of hits on google.com for weathertech.
Here is one that I found: http://www.macneil.com/store/prodsearch.asp?item_group_id=3
Mine are about 5 years old. There is a little wear on my drivers side where my left foot rests. Other than that they look new and they have done a good job keeping what I do not want off the carpet. ;)
