I need to replace the front pinion seal on my 05s front axle. Once you take the the u joint carrier loose and pull it to access the seal do you have to deal with checking the backlash or pinion depth etc. ? Or just remove replace and re tourgue the pinion nut ? Ive heard and seen mixed instructions on this. Just would like to hear from someone who has done it.
