LWorthington said:I sell one but will not have any ready for several weeks. We have several project turcks that get them first. Loren
HGreen said:Back in the mid 70's they use to make front axles trusses that didn't reguire welding, had a "U" bolt on each end that went in the knuckle and a metal plate under the pumpkin. Hickey made a nice one. I have searched many sites and it appears that no one still makes them. Has anyone seen them in today's market? Probably wouldn't take the rock crawling abuse, but would help the front handle the weight of the diesel.
ASchwartz said:I need one too.
Avi
Bob4x4 said:Avi I got a call this afternoon after you left the dyno,DesertFab Mikey has inspected a 9. 25 and has some ideas on how he will truss one. A rough estimate was also given I beleive.
Bob
JDerbedrossian said:So your saying projects before customers, or the other way around.
Jake
Jason Hughes said:I just finished trussing one in my shop and it is by far the nicest one to date. I refined mine a lot and made all new templates. It is made with 1. 5" . 120 wall chromoly tubing and steel plate. It is a very painstaking process to fit, weld, and keep straight. Unfortunately,I don't think a weld-on kit for an "in the truck installation" is possible due to many circumstances, of fabrication and welding processes, to have a good finished product. I will try to post some pics so you all can have some ideas on how mine is done. All I can suggest is that anyone doing these better be real good at knowing welding rod compatability and the welding process. I hope this was helpful.
ccutrell said:You can also look DRC for a truss ... ...
http://desertracingconcepts.net/accessories.htm
Look at the bottom of the page
Bob4x4 said:How about some pics,I have heard yours are different than Gregs or Jasons.
Bob
dsherman said:Bob,
Post some pics of your axle trussYou already have one mounted to your truck and is welded to the whole length of your axel housing.
Where did you get yours and who mounted it for you![]()
POST SOME PICS
David![]()
