I have been a member for several years now, but have don every little with my truck. I finally sold my Suburban, and now I have to get off my duff and make my truck a suitable tow vehicle before I retire from the military (3 years left). My Travel Trailer now sits in the storage unit until I get the truck ready.
I noticed the other day that my front driver axle seal is leaking. I found an excellent online article about replacing the seals (Front Axle Tech). I will use this as a guide.
While I am in there, what else should i replace? the ride has 210K on the clock. My rig needs to be reliable as possible. possible candidates I was thinking of: Ball joints, front axle u joints (i have a press), differential cover (with the Hag Hytec cover)
I currently have a Don Thruen track bar on the truck. I have had the track bar contact the front differential cover on hard bumps. I do not want to install the Mag Hytec cover until I have that fixed. I think somewhere I read that the front springs get weak over the years, that I need to use some kind of spacers on the coil springs to restore the ride height. If this is true, what do you recommend? I am not a fan of jacking this ride much higher than it already is from the factory.
If the recommended action is to install spacers, then I'll go ahead and replace the front shocks. I'm pretty sure the shocks are original also.
I need recommendations on what to do, and what parts to use. I only want to use better to best quality parts. I don't want to work on this any time soon.
Thanks!!
Thanks!!
