Front band adjust
Killer Dowl Pin--DC supporting defect?
TIE ROD END
Had time this weekend to take a ATF3 bath, removed the pan on my auto transmission. Have added a drain plug for next time. I was able to adjust the rear band only to find out the tools I have on hand to adjust the front would not fit. Looking for suggestions on tools to fit this hard to reach asjustment.
99 4x4 2500.
Thanks
brian , the easy way to do the front band is to loosen the jam nut , i think the screw is a #30 torx , put a 1/4 " allen wrench between the piston and the lever and snug the adjuster down , tighten the jam nut while holding the adjuster and your done . recheck to make sure the allen go in , and is not loose feeling .
Brian, I have done the adjustments several times with just a torquewrench, a torx socket, a torx L-key, and a box wrench for the jam nut. It is a pain to get in there but it can be done. I am curious to know also if there is a special tool or better technique to do it easier.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Rancho 9000's Everything but leather NRA Member Great Lakes TDR Member
I am not clear on where you placed the 1/4 allen wrench. I was going to use the proccedure in the service manual setting the torque with a torque wrench and some type of an adapter.
Apperciate another way of making this adjustment, would like more input.
Thanks Brian
Brian,
The way Mopar-muscle is suggesting is with the pan OFF. If the pan is on then do it like the book says. If the pan is off then the piston and lever he is talking about are those that engage the band oposite the side with the adjustment screw and front band anchor. If you are changing the ATF this is the way to do it.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
