2nd Gen Non-Engine/Transmission Front brake interchange
2nd Gen Non-Engine/Transmission 99 & UP SEIZED WHEEL HUBS
2nd Gen Non-Engine/Transmission Horn switch problems
I would like to know if it is possible to retrofit the 2 piston front calipers, spindles and lower control arms from a 2000>2500-2WD to a 94 2500-2WD? I would like to put them on my 94 2500, but a local Chrysler salvage parts counter man (somewhat ? ) told me that the frame and everything pretaining to the front suspention changed in 2000, so I am not sure if it can be done or not. I looked at a customer's 2001 today, and the control arm mountings look close to, if not, the same as the mountings on my 94.
If it can be done, I think it to be a worthwhile modification to get the better front brakes that the 2000> have and mine needs.
Thanks for any help you can give.
