I have a 01 2500 4x4 that is goign to be getting new front pads and rotors as soon as they come in. I have a couple of quick questions that I was not able to find the answers to with a search here or in my shop manual. Due to my screwy work schedule and my need for my truck to get to and from, I will likely either be doing this job at night after work or on a Sunday (either time is when most auto stores are closed!) So I would like to know what to get in advance. This is my first brake job on this truck but definately not first brake job I have ever done.
1) What size/type, wrench/socket am I going to need to remove the calipers so I can R&R the pads and rotors? I have heard a couple of different things.
2) Is there anything I need to remove to get the rotors off or will they just slide off once the calipers are out of the way, like other brake jobs I have done before.
3) Do the wheel studs attach to the rotors or are they the slide through type that are actually on the hub?
I dont have any other problems, but is there anything else that I should check or replace while the wheels/rotors/calipers are off?
Truck has 71,500miles btw, first brake job on it and it is more preventive than anything.
Thanks in advance,
J-
Thanks in advance,
J-
